Danish Limo 2,0 16v Project.
  • Ersteller Ersteller *Lkm*
Another picture update from Denmark.
Then it was time to repair the old rear fenders.
1977766-opel-kadett-c-2_0-16v-aargang-79-projektet
1977768-opel-kadett-c-2_0-16v-aargang-79-projektet
1977769-opel-kadett-c-2_0-16v-aargang-79-projektet
1977770-opel-kadett-c-2_0-16v-aargang-79-projektet
1977773-opel-kadett-c-2_0-16v-aargang-79-projektet
1977775-opel-kadett-c-2_0-16v-aargang-79-projektet
1977777-opel-kadett-c-2_0-16v-aargang-79-projektet
1977778-opel-kadett-c-2_0-16v-aargang-79-projektet
1977779-opel-kadett-c-2_0-16v-aargang-79-projektet
1977781-opel-kadett-c-2_0-16v-aargang-79-projektet
while rear fender was repaired, I started on the front which also needed to be replaced a little plate.
1977782-opel-kadett-c-2_0-16v-aargang-79-projektet
1977784-opel-kadett-c-2_0-16v-aargang-79-projektet
1977786-opel-kadett-c-2_0-16v-aargang-79-projektet
1977787-opel-kadett-c-2_0-16v-aargang-79-projektet
1989869-opel-kadett-c-2_0-16v-aargang-79-projektet
1989870-opel-kadett-c-2_0-16v-aargang-79-projektet
1989871-opel-kadett-c-2_0-16v-aargang-79-projektet
1989872-opel-kadett-c-2_0-16v-aargang-79-projektet
1989873-opel-kadett-c-2_0-16v-aargang-79-projektet
1989874-opel-kadett-c-2_0-16v-aargang-79-projektet
1989875-opel-kadett-c-2_0-16v-aargang-79-projektet
Then it was time to lay it on its side so I could get started with removing the old rust protection.
1989876-opel-kadett-c-2_0-16v-aargang-79-projektet
1989877-opel-kadett-c-2_0-16v-aargang-79-projektet
1989878-opel-kadett-c-2_0-16v-aargang-79-projektet
1989879-opel-kadett-c-2_0-16v-aargang-79-projektet
1989880-opel-kadett-c-2_0-16v-aargang-79-projektet
1989881-opel-kadett-c-2_0-16v-aargang-79-projektet
Thank you for looking.
Do not forget to give a comment
Lasse Denmark
Thank you.
I also expect a lot of parts that are out to be galvanized. and then there‘s various parts from opel-classic-parts.com to be installed next week. next step will be to clean some rust on the car
Hallo New update from the garage in Denmark.
Today the car was taken apart 100%, all windows, doors, wiring, headliner. was separated from the car.
So I am ready to make rust in the car.
2066723-opel-kadett-c-2_0-16v-aargang-79-projektet
2066724-opel-kadett-c-2_0-16v-aargang-79-projektet
2066725-opel-kadett-c-2_0-16v-aargang-79-projektet
2066726-opel-kadett-c-2_0-16v-aargang-79-projektet
2066727-opel-kadett-c-2_0-16v-aargang-79-projektet
2066728-opel-kadett-c-2_0-16v-aargang-79-projektet
2066729-opel-kadett-c-2_0-16v-aargang-79-projektet
2066730-opel-kadett-c-2_0-16v-aargang-79-projektet
2066731-opel-kadett-c-2_0-16v-aargang-79-projektet
2066732-opel-kadett-c-2_0-16v-aargang-79-projektet
2066733-opel-kadett-c-2_0-16v-aargang-79-projektet
2066734-opel-kadett-c-2_0-16v-aargang-79-projektet
2066736-opel-kadett-c-2_0-16v-aargang-79-projektet
2066737-opel-kadett-c-2_0-16v-aargang-79-projektet
2066738-opel-kadett-c-2_0-16v-aargang-79-projektet
2066739-opel-kadett-c-2_0-16v-aargang-79-projektet
2066742-opel-kadett-c-2_0-16v-aargang-79-projektet
2066743-opel-kadett-c-2_0-16v-aargang-79-projektet
2066744-opel-kadett-c-2_0-16v-aargang-79-projektet
2066745-opel-kadett-c-2_0-16v-aargang-79-projektet
2066746-opel-kadett-c-2_0-16v-aargang-79-projektet
2066747-opel-kadett-c-2_0-16v-aargang-79-projektet
2066748-opel-kadett-c-2_0-16v-aargang-79-projektet
2066722-opel-kadett-c-2_0-16v-aargang-79-projektet
Give me some feedback. what do you think of my project. it‘s always more fun with comments from other users when sharing your project
Lasse
Hey man, your project will be nice!!!
I´m from Brazil and have similar project with my Chevette GP II.
I was wonder if you could show how did you do the rolling equipment, if you could take some pictures of the equipment, and tell how did you suspended the car on the trunk, because the front is easy to see that you use the the bumpers hangers. What material did you use, and the sizes of the tubes?
It would be very nice and it´ll help a lot.
Hello every one.
News from denmark.
Project Driveline in the car
I have to check, if it all fits perfectly in the car, before it goes to the painter ;)
2151760-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151761-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151766-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151762-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
C20xe motronic 2,8
2151763-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
Manta 1,8s oil Sump
2151764-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151765-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151768-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
I have to adjust the manta 1,8 engine mounts.
2151767-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151769-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
C20xe with manta b 1,8s getrag 240
2151770-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151774-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
Not much space for the gearbox. but it will work ;)
2151771-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151772-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151773-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
Fit perfectly in the car
2151776-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151775-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151777-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151781-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151778-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151780-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151782-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
I have to make som spacers for the engine mounts. here in the drivers side i have to place som 20mm spacers between engineblock and the engine mounts
2151783-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
And 23mm spacers in the passenger side
2151784-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151786-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151787-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151810-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151811-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151812-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2151814-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
Installed with Manta/ascona b 5 speed driveshaft. 670mm. Then its plug and play ;)
Have i nice day.
Lasse
edumobili@gmail.com:
I use the bumber hole in the trunk.
Then i have 2 pipes inside the trunk. from the bumber holes to the lower fueltank mounts.
so the trunk panel not get damaged when you lift the car.
The tubes is 50x50x3mm thick.
Hope it will help you.
Lasse
New Car in the GARAGE ;)
One beautiful Kadett C 1979 1,6 Automatic with 32.000km from nederland. no rust/ never been weldet
now i am building on this.
2155638-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155639-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155626-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155627-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155628-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155629-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155630-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155640-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155631-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155632-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155637-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155633-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155634-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155635-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155636-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155641-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155644-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
2155642-opel-kadett-c-2_0-16v-aargang-79-projektet-part-2
